Fuel Sender
aero3113
Member Posts: 10,048 ✭✭✭✭✭
I was putting some more fuel in both tanks and to my surprise the port tank topped off at the filler. The gauge is only reading just above half. I unplugged the sender to make sure my wires weren’t crossed. The port gauge went to empty when I unplugged it , so the wires aren’t crossed. I noticed a small hex screw on the sender, what is that for? Is it to calibrate the sender to the gauge? I now have the starboard tank at full to match port.
I think you just need the correct length and the proper ohm replacement.
“ I definitely need the part number off of the fuel sender. The part number will tell me the ohms info, length, about the leads, etc.”
A full tank means fuel everywhere when you pull the sending until.
I keep a small 12v fuel pump just for pumping fuel out. Get a good 20 gal worth of fuel cans, run a fuel hose out of your drain plug hole and do all your fuel pumping safely in the yard.
When done pour her back in.
I have a carb so its easy to tie into a fuel hose. Your efi may give a little more headache.
On cars i have given 12v directly to the fuel pump to drain the fuel, easy to do it you can access the fuel relay. Having a wiring diagram lets you know which prongs to jump. Key on = fuel on. Key off = fuel off.
