Run Blower while Gen Set on?
oscar1oscar1 Member Posts: 804 ✭✭✭
should i ran the blower while on hook with the Gen Set running? what do you guys do
    Always, mine is set so only one of the 2 blowers run when using generator
    2002 Rinker FV 342
    Yes sir, every year we read about a family died in there sleep. also check your CO detectors. If you don't have one install one.
    Yes but switch the blowers on using the switch on the panel by the genny start button, not the switch at the helm, this should only run the blower on the opposite side of the boat than the genny exhaust so you are not bringing in fumes. Blower switch at the helm runs blower on both sides of the boat. Also make sure you have at least two co detectors down below that work.
    Always.
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    I always run the blower but never knew the switches made a difference.  Thanks for the info.
    Ray
    2006 390
    Previous 2000 340
    Yep, I learned from mr @Black_Diamond
    @Black_Diamond is very knowable on the 342. Great source of info.
