Help me diagnose a power steering issue
LaRea
Member, Moderator Posts: 8,075 mod
Recommissioning my 370 after a major rebuild with new transom assemblies ... the power steering feels stiff and jerky. It goes through the full range of motion, but the steering effort is too high, and it feels jerky and uneven.
It's not a pump issue. Today I swapped the port steering pump over the starboard side, and it didn't help. The hydraulic fluid is new. I don't see air bubbles in the steering fluid reservoir, and I've already worked the wheel back and forth about 1000 times. I fixed a slight kink in the hydraulic line to the cooler ... no joy.
What would make the steering feel jerky and uneven?
No power steering, 20 pounds
Normal power steering, less than 1 pound
My steering: 5 pounds, but sometimes it briefly drops to 1 pound
That's why I say it feels jerky. While I'm turning the wheel, sometimes it will feel "normal" for just a fraction of a second, then back to 5 pounds of effort.
A problem with the steering cable or transom assemblies would be a constant force, so I think it has to be hydraulics. @Handymans342 it could be in issue with the ram after sitting in my attic for five months.
How would I test the pressure?
Start the motors at the dock, idle rpm and slowly clock the steering from left to right for the duration of your favorite power rock ballad. "Don't stop believing" that it's something simple.
I just rebuit my trim cylinders and it took maybe 10 min up and down working to get it to stop whining under load.
Ive had cars that needed a few days to fully purge after swapping a power steering pump
Filling And Bleeding - Mercury MerCruiser MCM 4.3L ALPHA Service Manual [Page 16] | ManualsLib
I ran the engine at high idle and cranked that wheel every way I could for about 15 minutes: slow, fast, pinned against the end stops, you name it, I tried it. There are no bubbles in the reservoir, and it's still really hard to move the wheel.
@goalie59 the wheel tilt position didn't change anything.
Not a steering cable problem (Wheel moves freely when cable is disconnected from actuator.)
Not a problem with the port transom assembly (Port steering pin moves freely by hand when disconnected from tie rod.)
Not an autopilot issue (Autopilot cable moves freely by hand.)
No visible interference or binding in the tie rod or other components.
By process of elimination, it has to be the power assist actuator. There's still an air bubble, or maybe a piece of debris somewhere inside the actuator.
