2000 270FV Power Trim Pump
I believe I have water in the reservoir of the pump that raises/lowers the lower unit. What are my next steps? I assume drain lower unit and refill the lower unit and the reservoir. Is that the correct thing to do first? Or, is there a way to troubleshoot prior to drain/refill? The boat is on a lift with the lower unit out of the water. Thank you for your help.
  • YYZRCYYZRC Member Posts: 5,492 ✭✭✭✭✭
    That is the pump for the trim rams, you can disassemble the rams to clean them out.  Maybe you have a leaking line that let water in?
  • rasburyrasbury Member Posts: 8,986 ✭✭✭✭✭
    Yes, nothing to do with the lower unit other that the rams are on it...probably a bad seal...and depending on the water damage, salt vs fresh, I'd say your best bet is to replace them..you might get by a while if it is just one on the lines- if someone had it apart and a fitting is lose I'd tighten it and give it a whirl but be prepared!
  • JarodjayJarodjay Member Posts: 29 ✭
    What do you mean the "rams"?  Always fresh water.
    Trim rams:
    Thank you. Perfect picture. I will look when I get back to the boat to understand what I am getting into!
  • GMSLITHOGMSLITHO Member Posts: 1,619 ✭✭✭✭
    Fairly simple to rebuild the rams it’s a kit ,the lines are a little bit more difficult to do ,as far as getting down inside the boat
    @Jarodjay if you end up needing a set of rams, I have some used ones in good shape that I need to sell.
