Sealing screws
I recently removed, cleaned and am putting back my thru-hull Corsa Captains call exhaust port cover.  When I put the screws back in I assume I should put some type of marine sealant on these since it is close to and will be below the water line at times ?  What should I use ?
    3M 5200
    I would choose 3m 4200
    2002 - 270FV Mag 350 B3
  • kennydalglishkennydalglish Member Posts: 93 ✭✭
    These are good to use on screws that I need to unscrew at times ?  Not a loctite type ?
    4200 or even Lifecaulk sealant
    Don’t listen to @raybo3 because 5200 is only for underwater
    4200 not 5200
    He said it goes underwater. Read his post Handy or did you forget how to read.
    Read again dumbo. The exhaust tip rarely ever goes underwater. 4200!!
    Sorry to start a commotion here lads.  Just bought the boat and assume that the exhaust will see quite a bit of water so was looking for something that is good for putting on screws but still need to remove the screws if I need to replace the exhaust cover.  Looking at research on the 4200 vs the 5200 it looks like they both will work however 4200 may be the better option since 3M states you can remove unlike the 5200.
    Thanks again.
    Handy and Ray are best buds so if they are not going at each other there is a problem :)
    The great Rinker forum debates.
    4200 vs 5200
    Diesel and gas
    Hardtop or no hardtop
    🤣 Welcome to the forum @kennydalglish
    4000 ftw
    4200 vs 5200
    Diesel and gas
    Don't forget white or dark hull.
    Hardtop
    @Handymans342 I guess you really cant read " since it is close to and will be below the water line at times ?" That is a direct quote. See it "below the water line at times ?" What is it about BELOW THE WATER LINE you don't understand? Anything that goes below the water line for any amount of time should be 5200. @kennydalglish your not starting anything between me and Handy. Simply put he thinks he knows everything....lol Handy is really a great guy and we go at it on everything but all in fun......
    I love Raybo like a brother except he is just dumb as a rock unless it concerns trains or cross dressing.
    Come on handy, you know you look better in the wig and walk better in high heels 🤣🤣
    This is what I use below the waterline. My trim tabs and transom lights all have a crap load of this under them as of a few weeks ago:
