JOHNNY CARTER
2017 29' RINKER   WILL NOT LET ME FILL WITH GAS
Best Answers
    Answer ✓
    Is the boat sitting very unlevel?  That's the only way I can imagine there would ne fuel in one side of a single baffled fuel tank and not the other.
    I had a 60 gallon tank that would only hold 40 on the trailer as she sat bow up.
    Answer ✓
    Was talking to a friend on the dock this weekend and he mentioned that he had the same issue which he just resolved. His issue was that the fill hose leading from the fill to the tank was ran very poorly and went up and down like a horizontal P trap which created a lot of resistance. Once it was ran in a more straight direction, no more fill issues. So make sure your fill hose is pretty direct to the tank.
    edited May 2021
    Is this due to a fuel shortage issue?
    Or does it keep bubbling and over filling?
    If the second one is the issue you have a breather house issue, needs to be a gradual slope from tank to breather, any dips can hold fuel and cause vent issues.  Also bugs or corrosion can block the vent screens where it exits the hull.
      A full tank in the winter will swell to an over flowed tank when it warms up.  Any dips in the hose can catch that excess fuel.
  • JOHNNYERWINJOHNNYERWIN Member Posts: 9 ✭
    I RAN OUT OF GAS WHEN I TRY TO FILL IT UP IT WOULD ONLY TAKE 30 GALLONS  THE TAKE IS 75 GOLLANS I THINK
    What does your fuel gauge read?
    No need to yell! Andy
    full, and when it reads 1/2 tank it drops of real fast   you can see gas if you open a access hole in the middle of the boat. but none at the back.. when it was empty i could only put 30 gallons in  i drove around town stop back gas station  and i was able to get 7 more gallons in  if you squeeze the were it dribbles out
    If you verified your tank was empty and you read full at 30 gallons you have a fuel lever issue.  You can pull the lever unit and test it via a multimeter.
    Have some Permatex pipe dope that is fuel rated on hand and some rags on hand to re install.
    If adding fuel is that slow i think you have a vent issue as well as a fuel sending unit issue. Impossible to tell without being there to inspect and test
    edited May 2021
    You shouldn't have to pull the sensor out to test unless you want to move the float and see the readings. If you know it is full then you can test it to check the resistance on a multimeter.
    This is a 290EC? Are you sure it is the fuel tank you are filling, not being rude but I don't know if this is your first time with the boat? I'm confused about the access hole and not seeing fuel at the "back" ?
    I hope he's not fueling the waste tank!   Some potent poop juice mix he'll have there.
    no this is my 11 boat  not a rooky!!!   but it's got me stump  why i have 75 gallon tank and i can only put 30 gallons in it.  I took all the hoses off and blew them out  even took the charcoal filter off I even cleaned the wire screen on the port side. you can see gas at the front of tank and none at the stern under the hatch  It just wont let me fill her up.  29' rinker captiva
    Oh ok Captiva this is different then I was thinking. Thought it was a 290EC.
    Yeah sorry didn't mean to offend but figured I should ask since the east tanks are almost 30 gallon. I actually started to unscrew my waste tank cap my first fill up this year then realized oops 😬
    THANKS FOR EVERYONES INPUT    ITY'S NOT FUN RUNNING OUT OF GAS IN THE GREAT LAKES!!!
    Either the tank is already half full, or the tanks vent is clogged.
    Sounds like a blocked baffle plate. Do you have a Milwaukee scope?
    NO BUT I WILL CHECK INTO THAT  THANKS
    Usually the baffle plates have holes to prevent sloshing around inside. You probably know this.
    edited May 2021
    You may be able to rent a scope
    Handy wouldnt the fuel go over a blocked baffle? Or are they 100% of the height of the tank? Thought they were only partial height.
    @JOHNNYERWIN - Is your all caps key broken?  Lol
    2002 - 270FV Mag 350 B3
    I don’t know Lib but would love to see inside with a scope
    WHAT HAPPENED TO JOHNNY
    He got fueled up and is out of cell phone range.
    It's over Johnny....it's OVER!!!
    still working on it   thanks for all the helpful hits
    @JOHNNYERWIN you make one post and get 25 comments, welcome to the forum and the tough crowd.
    We just need answers
    I WILL POST,  IT  WAS VERY HELPFULL HAVING ALL THE HELP  AND IDEAS WHAT TO LOOK FOR   I THINK I'M GOING TO BUY ONE OF THOSE MILLWALKIE SCOPES
    Start with the filler neck
    does anyone know were the radio amp might be on a  29 captiva rinker???
