I don't know what is this and how it works
Please can somebody explain to me,
thanks
  • aero3113aero3113 Member Posts: 9,853 ✭✭✭✭✭
    edited July 2021
    That’s your depth display. Does it power up? If not check for power behind the dash to it, also check breakers and fuses that might be inline.
  • LaReaLaRea Member, Moderator Posts: 8,069 mod
    It should come on automatically when you turn on the ignition, but try pressing the button at the bottom.
    I am going to change mine to the accessory switch. I was at anchor in the middle of a thunderstorm recently and had to turn on the ignition switch so I could monitor depth. I also want top leave it on at anchor overnight for an alarm if I enter shallow water.
  • YYZRCYYZRC Member Posts: 5,464 ✭✭✭✭✭
    @Grahamu check out “Anchor Pro” in the App Store. Great app!!
    It's a depth sounding display that has an alarm that tells me my boat is in the slip. Andy
    That’s a good idea!
  • JonSnowCancunJonSnowCancun Member Posts: 6
    thank you, it works perfect  but i don't know how to use it, does somebody know a manual, every time i start the boat start beeping, i press all the bottoms until stops beeping.
    Faria IS0091F manual attached.
  • GMSLITHOGMSLITHO Member Posts: 1,618 ✭✭✭✭
    First boat ?
    fist boat with this, i had two small boat before, 19 ft campion, and a 15 ft wellcraft, Thank you for your help
    LaRea thank you,
