I don't know what is this and how it works
Please can somebody explain to me,
thanks
  • aero3113aero3113 Member Posts: 9,960 ✭✭✭✭✭
    edited July 2021
    That’s your depth display. Does it power up? If not check for power behind the dash to it, also check breakers and fuses that might be inline.
    It should come on automatically when you turn on the ignition, but try pressing the button at the bottom.
    I am going to change mine to the accessory switch. I was at anchor in the middle of a thunderstorm recently and had to turn on the ignition switch so I could monitor depth. I also want top leave it on at anchor overnight for an alarm if I enter shallow water.
  • YYZRCYYZRC Member Posts: 5,498 ✭✭✭✭✭
    @Grahamu check out “Anchor Pro” in the App Store. Great app!!
    It's a depth sounding display that has an alarm that tells me my boat is in the slip. Andy
    That’s a good idea!
  • JonSnowCancunJonSnowCancun Member Posts: 6 ✭
    thank you, it works perfect  but i don't know how to use it, does somebody know a manual, every time i start the boat start beeping, i press all the bottoms until stops beeping.
    Faria IS0091F manual attached.
  • GMSLITHOGMSLITHO Member Posts: 1,619 ✭✭✭✭
    First boat ?
    fist boat with this, i had two small boat before, 19 ft campion, and a 15 ft wellcraft, Thank you for your help
    LaRea thank you,
