Follow up question regarding Micro Wave problem
jandavjandav Member Posts: 41 ✭✭
In my question about the Micro wave I have found out that I have to replace the Micro.
https://rinkerboats.vanillacommunities.com/discussion/12798/microwave-problem#latest
Rinker installed the Micro in our cabin so I cane get it out through the whole that sits in, I need to remove the complete front panel and my question now is HOW do I do that....
I guess that I have to remove a lot of screws but which one...
Anyone that has dissembled this part of the kitchen?
Thanks in advance for any help
/Jan (from sunny Sweden)
  • jandavjandav Member Posts: 41 ✭✭
    Here is a picture showing the panel that I need to remove to be able to replace the Micro.
    I can see that it is screws behind the door but where are all the screws that needs to be removed?
    /Jan
    Are there screws under the microwave going in to the shelf Below the unit?
    edited August 2021
    I removed the microwave on my FV250. Look underneath the microwave and you should see some screws. Those screws attached to a plywood board that is attached directly to the bottom of the microwave. You can then slide it out, however in the case of my boat I had to cut the power cord to do that. I have installed an electrical outlet and I'm using the space for storage. Andy
    My problem is that the plywood board that the microwave is attached to is not in the center of the microwave, that makes the microwave+plywood board together too wide for just slide out.....
    It is therefore I need to remove the front panel to be able to replace the microwave.
    I have already found the screws under the shelf, it was after removing them I realised that I need to remove the complete front panel.
    Thanks again for all help!
    /Jan
