Tight shift cable fix
toolmaker312
Member Posts: 130 ✭✭
I was having problems finding due to the tight cables. I took the shifter apart and took off the cable. I found a clear plastic tube to tightly go over the the end of cable. I then filled tube with oil and forced it in with a compressor. It came out the other end by the engine. Success. Now I need to adjust the cable that is stretched from all the friction.
