Trim operation
rasbury
Member Posts: 9,027 ✭✭✭✭✭
I've had our 270/bravo 3 for about 8 years , trim has been an issue...seems like it worked ok and then only goes up with the trailer switch. I have re sealed the transom so everything came out. I put new sensors on the out drive and now they don't work right either. I have looked over connections and such, tight and corrosion free. I always read the breakers at the pump are usually the culprit but this sounds like maybe more of a switch in the handle...anyone walk me through checking with a meter for voltage etc? It works fine down, will work up with trailer switch.
Blue = Up (Blue Sky)
Green = Down (Green Grass)
here’s a pic of the solenoids:
Thanks @Cableguy Greg...you have bailed me out on a couple of electrical issues....
Thanks again-
