Cables on out drive
rasbury
Member Posts: 8,972 ✭✭✭✭✭
Well...I guess some time back when I was touching up my out drive, there are 4 short little cables that I guess ground each major outdrive component? I took off ends where I wanted to paint...apparently lost the screws and always figured I'd get them...and forgot. What exactly are they? Would the screws be aluminum? I'm looking on parts sites and can't seem to find them...
https://nuwavemarine.com/uncategorized-mercury-parts/oem-quicksilver-mercury-mercruiser-continuity-kit-alpha-bravo-gen-2-bravo-99940a-2/?gclid=Cj0KCQiA54KfBhCKARIsAJzSrdpGSCeWyWZJpWgflO7edCs1hLPm4xK5xu9rZ6KPi_IJ5_LZDNeI8u0aAmp0EALw_wcB
Did mine last year replacing the ones that were missing and/or broken
There's also another continuity cable that goes from the bell housing to the gimbal.
Plus, the temps are dipping...must be down to 70 by now....brrrrrr....
I have been all over the rams I can't figure those two out- but have not been underneath...do you recall where they attached? The only thing I can guess with the ram off, there is a bracket for the one trim line on the inside side of each ram , plus the islet for two dangling straps are larger.
I'm going to have to pull the rams anyway to get the water out of the system plus something is making a God awful noise from one of the rams. I though one of the anodes were crudded up enough to cause a bind but I pulled them...
