Batteries discharging
rasbury
Member Posts: 8,971 ✭✭✭✭✭
Never thought my batteries held a charge well. I have new batteries and up until last week was at the house on the charger. I have a little 12v plug-in to tell me the charge on the batteries and it was showing charge. I put it in storage snd over about a week they are dead, battery switch is off and the accesory switch off. How do I figure out what is pulling it down? I know there are things that will still work-: trim, vhf, bilge pumps...it is the original charger. I assume while charging it does not matter where the battery selector is? If I'm charging and a meter would show over 12 volts it is acceptably charging? I don't want to install a "master" power cut off somehow for storage but not sure what else to do...
I'd venture to say your have a bad battery(ies) before a parasitic draw. Battery quality sucks these days.
If possible remove batteries and bring them home where you can put them on a low amp charge for 8 plus hours. Then load test them. If you can't load test them take them to an auto parts or battery supply store and they can load test them.
If they test good you can then look for parasitic draw. There are some good YouTube videos on how to test amp draw with a simple multimeter. You pretty much just attach one probe to the battery and the other to the disconnected (pos iirc) battery cable. Then you unplug each and every fuse looking for a drastic drop in amps.
If the batteries are drawing down while the battery selector switch is off you can focus on accessories that are wired directly to the battery. A bilge pump float being stuck will drain a battery and would be the first thing I'd listen for.
Your battery charger, with good batteries will be putting out 13 to 14.5 volts while turned on. If you have an extremely dead battery it may read less depending on the amperage settings. A good battery at rest will have 12.5 to 12.6 volts. If you check the battery immediately after being removed from a charger it will still read 13 plus volts for a bit.
If testing with a multimeter is too daunting you could verify the switch works and then remove the fuse out of each item connected to the battery one at a time. When you unhook the one that is killing battery your problem will then go away, so long as it's not a combination of little parasitic draws.
My last issue with this was on a 6.0 Ford powerstroke f450.
I'm assuming a diode in the alternator went bad as that was my cause of a very significant amp draw while sitting.
New alternator cured it. I had been through every fuse and relay inside the cabin and under the hood 3 times before I found the alternator being the culprit
Sadly with electrical you only see the issue when it's so bad you're letting the smoke out of it.
not sure what to suggest other than onboard charger is done.
Sorry I didn't respond earlier, I'm also getting my boat ready for the first launch.
As for the breaker panel I cannot answer that as I've not had one apart in ages. My Bayliner uses a fuse panel.
But if your batteries are discharging while battery selector is in the off position you shouldn't have power to your dash. That means it's likely one of the times that attach to the battery before the battery switch, items that are always hot. Bigle pumps, CO2 detectors, engine bay fire extinguisher system...etc. I'd only check dash switches if she's dying while battery is in the on position.
lol - ours are opposite. Go thru house batteries at 2-3 times faster than starting batts.
After getting all the fuel out of my tank and getting some fresh fuel in it back to the ramp to test. First crank sounded good and strong pulling fuel into the system. Probably still bad fuel in the cylinders or crap in the injectors. Couple more cranks and it's starting to sputter a bit trying to start. And then with the turn of the key it makes this sound like something is shorting...maybe the selonoid is clicking/sticking or something and then the key is dead for anything out of the starter. All my accessories seem to work. I do not get beeps like normal when I turn the key to on. I bet I could, if I did not just ruin a new battery, go to the boat tomorrow and it would turn over. It did this before killing the battery but just suspected a bad battery. The stater selonoid on the top I just replaced and it is not tripping. I guess at the very least I need to check the connection at the starter. Is the selonoid the power to the starter to engage the starter motor and the flywheel? Not a selonoid at the starter like a car starter? I would add that about 3 years ago , long story, but the bilge flooded and submerged the starter and I've been waiting for a problem ever since. This is the original starter and I had it rebuilt when we first got the boat 200 hours ago...
You can remove yours and take it to an auto parts store, tell them it's from a Chevy 1500pickup truck the same year as your boat. They should test if for free if they don't catch on it's a marine starter.
For what it's worth, I also used API alternators, and they both failed after 2.5 years/100 hours. I'm not sure if I did something wrong, or got two from a bad batch.
https://www.amazon.com/gp/product/B00SVE6NIK
https://www.wholesalemarine.com/mercury-mercruiser-50-863007a-1-starter-assembly/
