Rinker Blue Hull touchup?
I have a Rinker with the blue hull on the side. Looking fot the best way to restore it over to winter? Any thoughts or recommendations?
    I had mine wet-sanded by a detailer.  Made it look brand new.  That's the only way I know to bring back chalky gelcoat.
  • rmrstlmormrstlmo Member Posts: 238 ✭✭✭
    I also had mine wet sanded when I bought it.  See before and after pics.
    Ray
    2006 390
    Previous 2000 340
    @tricountytrail
    Depends if you are going to do it yourself or hire it out.
    Personally I would just give it a go yourself.
    7" quality buffer & 3M wool pads will easily clean that up with compound.
    Once you get it in good shape initially - easy to keep it up & protect it if you work at it each year.
    Mine was beyond what you can achieve with rubbing compound.  I used to have a pro do a full compound-polish-wax job in the spring, but it would be chalky by mid-season.  After he wet-sanded, all it needed was wash and wax twice a year.
  • YYZRCYYZRC Member Posts: 5,475 ✭✭✭✭✭
    Huge transformation @rmrstlmo !
    Yes, I was very happy with the results!
    Ray
    2006 390
    Previous 2000 340
  • tricountytrailtricountytrail Member Posts: 257 ✭✭
    Thanks for all the suggestions. once I haul it I will check it out.
