Spot light 2002 342 fiesta vee
cls10105cls10105 Member Posts: 389 ✭✭
Hello everyone me again with the damaged boat and empty wallet. My spot light stopped working I am not sure why it won’t move / rotate or anything. Does anyone have any suggestions.
Thanks Charles
cruising on 6. tw0s
  • aero3113aero3113 Member Posts: 10,034 ✭✭✭✭✭
    What spotlight do you have?
    Did you replace the batteries in the remote if it’s that style?
    Gotta be the old-school Jabsco on a 2002.  Check the fuses in the joystick controller.  On the face of the controller, there should be two little plastic rectangular fuse covers that just pull off.  What happens if you try to physically move the spotlight by hand?  If it moves easily, the gears are probably broken (which is fatal).
    If no joy there, you can try removing the case from the spotlight to look for anything obvious.  Loosen the ring around the rim of the bulb and pull it off.
  • cls10105cls10105 Member Posts: 389 ✭✭
    So I need to take the joystick out and behind it are the fuses?
    cruising on 6. tw0s
    No, on the faceplate above and below the stick
  • Pat310Pat310 Member Posts: 606 ✭✭✭
    Thank you so much. I had no clue that’s what that was!
    cruising on 6. tw0s
    You know years ago I thought they were just finger grips as you toggled the stick!
    I had no clue what it was for. I really appreciate you guys for all your help!
    Thank you all so much!
    cruising on 6. tw0s
    it was the 10 amp fuse the was fine but I went ahead and replaced it also!
    Thanks everyone for all your help!
    cruising on 6. tw0s
    cruising on 6. tw0s
  • rasburyrasbury Member Posts: 9,012 ✭✭✭✭✭
    Well next it will be figuring out why it blew- keep spares!
