Switches/lights
rasbury
Member Posts: 9,039 ✭✭✭✭✭
Our 270 has two courtesy lights- i replaced one with a nice blue led- should have bought two- i looked on great lakes abd also amazon but not finding a replacement- these are 1/2" dia best guess...also, my rocker switch for the hatch puked- is that considered a 3 way or two way switch? Will I find one that will fit and be pined the same? I have not pulled the switch for a part number but it is 2006...
If the replacement switch isn't a direct replacement with the identical pin arrangement it would be a nightmare for most to replace.
Momentary (turns off when you release it)
Dual pole, dual throw (DPDT) on-off-on (button up raises the hatch, down lowers it)
It'll be one of these two:
https://newwiremarine.com/product/hatch-rocker-switch-contura-ii/
https://newwiremarine.com/product/hatch-rocker-switch-contura-v/
Thanks to all for looking at my post and trying to help!
There's a chance you can make a 6 prong work, losing the backlight but you'll need to be good with a multimeter to find out the prong wiring.
Plug and play from a direct fit 8 prong would be much less of a headache.
Most of the year I don't care for the backlight switches but as fall approaches and the sun goes to bed much we earlier, I don't like having to fumble around for the switch I want to hit.
Actually it must be as there is not dark spot in the middle where this is.
