Outdrive "slipping"
grouch0jrgrouch0jr Member Posts: 253 ✭✭✭
Mercury engines with bravo 3 drives.
While taking her out yesterday we got up on plane, then almost immediately the starboard engine RPMs increased and we fell off plane. We made sure the drives were all the way down and tried a couple more times. We couldn't get up on plane and stdb RPMs would shoot up, felt like it was "slipping" under load. We were able to limp back to the dock, and we were able to use the both engines to maneuver while docking, although it didn't quite feel right.
Once tied up at the dock we put the drives in the trailer position and did the "reach around" to check the props. They were both in place and didn't seem fouled. I check the gear lube reservoir and the level/color was not abnormal. I don't think its an outdrive probelm, it was a brand new SEI installed at the beginning of last season. I've read some threads that indicate it might be a failing coupler. I didn't smell any burnt rubber down in the hatch. Is there any way to check the coupler while it is installed? I saw that engine alignment can cause this problem, but I've never checked the alignment.
Also, any other ideas?
I figure I need to get the boat pulled... First thing I'll check will be to drain the gear oil and see if its full of glitter.
    Sure sounds like the coupler to me- but I would not think there is anything in-between I lost mine on the water...was coming off plane and going slow- but there was no slip, burnt smell of rubber etc....I know you did not experience the latter. Unless something in the clutch /gears let lose. Its a pretty simple set up...
  • grouch0jrgrouch0jr Member Posts: 253 ✭✭✭
    I saw some other threads mentioning the cone clutch. Is there a way to narrow that down?
    The only real way to sort out the cone clutch is to take the drive apart. A bad cone clutch will also exhibit a delay when engaging, once the engage they typically don't slip after.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,956 mod
    I agree with the coupler as well.  So, when you say you've never had engine alignment checked, how long has that been?  Not that it is your issue, but I have my boat pulled every single March to have alignment checked (and anything else in the drive area if it needs it coupler, gimbal bearing... like this year was a new gimbal bearing).  Now, my boat is a bit heavier and harder on the drives.   You also should be greasing the coupler once a year.
    I just got the boat last season, so I'm not sure how long it has been. I also did not know to grease the coupler.
  • aero3113aero3113 Member Posts: 9,974 ✭✭✭✭✭
    Any chance you hit anything while getting up on plane? The coupler is the fail safe between the drive and the engine.
    If your props had hubs, like mine, I’d say it sounds like that.  But B3 props don’t
    Its POSSIBLE I hit something, but we didn't feel or hear anything. I also have been thinking that maybe something was fouling the props, but maybe it cleared itself while we were docking (shifting between fwd and reverse).
    I just got back from the boat. I took a look at the couple and didn't see any signs of debris or rubber dust. I also fired up the motor and shifted into fwd/reverse several times with a friend listening for sounds from the drive. I was getting thrust in both directions and there weren't any sounds.
    After all that I noticed by trim reservoir was almost empty, so I topped it off and then noticed an oil slick out the back of the boat. I think once of the hydraulic ones to the trim ram may have ruptured? I don't think this could cause the other problem, but may have the same cause....
    When you said you made sure the drives were all the way down, did you visually verify? If your trim pump is leaking that bad, it’s possible the drive is stuck in the up position.
    You may still get thrust at low revs until you break friction point. My old Bayliner with alpha did the same one day - revs took off while we slowed down. Didn’t hear anything but spun the hub out, limped back in near idle revs, anything more just spun free. Like @a@aero3113 suggested, sounds like coupler
    Water here is murky, so i couldn't see visually. My trim sender/gauge function though, so I used those. I didn't look at the gauge while giving it throttle and trying to get on plane, but I did before and after. Is it possible the drive could lift itself up while under power?
    Theoretically yes but unless the manifold under the Mercatode totally let loose, even blowing both tubes on one ram there other side should hold it in place. From recent discussion with my mechanic - while replacing rams, tubes and manifolds - the valve operation on these control pumping up and down so you’d need all 4 to blow out before the drive would freely flop up and down. These aren’t light either.
    So I used a paint pen to mark a straight line on the coupler (both the rubber and aluminum parts) and the outdrive drive shaft, then took the boat out. While on the test run we experienced no slipping and easily got up on plane. Cruised for about 20 minutes issue free. After getting back to the dock I checked the markings I made on the coupler and everything was still aligned.
    I don't think there is a problem with the outdrive itself because it shifts perfectly fine, so it seems the original issue was something like a clump of weeds fouling the prop ¯\_(ツ)_/¯, I guess I should count my blessings. I still need to fix the trim, but that's not a show stopper.
    Thanks for everyone's input.
