Outdrive "slipping"
grouch0jr
Member Posts: 204 ✭✭✭
Mercury engines with bravo 3 drives.
While taking her out yesterday we got up on plane, then almost immediately the starboard engine RPMs increased and we fell off plane. We made sure the drives were all the way down and tried a couple more times. We couldn't get up on plane and stdb RPMs would shoot up, felt like it was "slipping" under load. We were able to limp back to the dock, and we were able to use the both engines to maneuver while docking, although it didn't quite feel right.
Once tied up at the dock we put the drives in the trailer position and did the "reach around" to check the props. They were both in place and didn't seem fouled. I check the gear lube reservoir and the level/color was not abnormal. I don't think its an outdrive probelm, it was a brand new SEI installed at the beginning of last season. I've read some threads that indicate it might be a failing coupler. I didn't smell any burnt rubber down in the hatch. Is there any way to check the coupler while it is installed? I saw that engine alignment can cause this problem, but I've never checked the alignment.
Also, any other ideas?
I figure I need to get the boat pulled... First thing I'll check will be to drain the gear oil and see if its full of glitter.
2006 342EC - Twin Mercruiser 350 MAG MPI Horizons
