bad starter or worse?
FlyingBlind310
Member Posts: 49 ✭✭
Question...went down to the boat last weekend and tried to turn over the port engine but nothing happened (no sounds/clicks). Starboard engine fired up no problem and my battery voltage was good. Also double checked my throttles-neutral. Hit the switch again....no sound and then held it again for an extra second and it started to crank & fired up. This happened again with the same results after 4 hours at anchor. Boat ran well with no other noticeable issues.
Could this be a wire connection issue battery/starter/ignition?
Could this be a hydrolock symptom?
Maybe bad starter?
Just want to get some opinions before I call the marina to investigate or attempt on my own.
Much appreciated...-JJ
2001 310 Fiesta Vee
T-5.0 FWC Mercs w/ B2
edited to add: you can either by-pass the solenoid, or swap it for the one on the other side to confirm, but those are classic symtoms.
what is it and do I have on the 350 merc?
Sierra # 5817 or 5816
2001 310 Fiesta Vee
