bad starter or worse?
FlyingBlind310FlyingBlind310 Member Posts: 49 ✭✭
Question...went down to the boat last weekend and tried to turn over the port engine but nothing happened (no sounds/clicks). Starboard engine fired up no problem and my battery voltage was good. Also double checked my throttles-neutral. Hit the switch again....no sound and then held it again for an extra second and it started to crank & fired up. This happened again with the same results after 4 hours at anchor. Boat ran well with no other noticeable issues.
Could this be a wire connection issue battery/starter/ignition?
Could this be a hydrolock symptom?
Maybe bad starter?
Just want to get some opinions before I call the marina to investigate or attempt on my own.
Much appreciated...-JJ
2001 310 Fiesta Vee
T-5.0 FWC Mercs w/ B2
    edited June 2014
    slave solenoid atop the engine most likely on it's death throws.. $15 fix or so..
    edited to add: you can either by-pass the solenoid, or swap it for the one on the other side to confirm, but those are classic symtoms.
    I'll 2nd Drews comment.
  • rasburyrasbury Member Posts: 8,925 ✭✭✭✭✭
    Might be the problem I have on 270
    what is it and do I have on the 350 merc?
    Ras: yes you have it too.  Right behind the throttlebody there is a red button (circuit breaker) there is a $20 solonoid mounted to the same bracket...the same solonoid used on the Merc drive trim pump (2 per pump) if I am not mistaken?  probably a 30 min job including disconnecting your batteries: easy!
    I can confirm it's the same solenoids on the trim pump too. My starter solenoid went out last year as well as the trim solenoids. Easy to put a jumper across to confirm the issue. Hope that's all there is to it. Mike
  • picturethispicturethis Member Posts: 103 ✭✭
    edited June 2014
      sounds like a a good thing to carry a spare onboard
    Sierra # 5817 or 5816
    Post edited by picturethis on
    I am a new boater with my first boat,  thats why some of my questions seem dumb
  • brianluckbrianluck Member Posts: 174 ✭✭✭
    Had the same issue, slave solenoid fixed it like stated above.
    1994 300fv "General Madness"
    Rebuild starter. Problem solved.
  • FlyingBlind310FlyingBlind310 Member Posts: 49 ✭✭
    thanks for the input/help....i will hopefully get down there this weekend and investigate.
    2001 310 Fiesta Vee
