Access panel for AC unit on 2005 Rinker Fiesta VEE
Does anyone know how the access panel comes off on the 2005 RInker Fiesta Vee? There are two pins on the side but when I pull on the panel it does not snap off and feels like it will break if I pull **** it. The two pins look like plastic rivets almost.
Its a 2005 Rinker Fiesta vee 270
I can but it will take me a day or so to get back down to the boat.
ok, apparently the access to the AC unit is under the mattress and not in the wall, so I believe that I am all set. Thanks for your help.
That is the access to your ac unit, the panel with the 2 plastic caps.They simply pop off and there is a phillips head screw under each 1.Remove the screws and the panel comes off and you will have access to your ac unit.
Anything that looks like a button pops off and a SS phillips head screw is under it on the interior
