Access panel for AC unit on 2005 Rinker Fiesta VEE
Sburns090964
Member Posts: 4 ✭
Does anyone know how the access panel comes off on the 2005 RInker Fiesta Vee? There are two pins on the side but when I pull on the panel it does not snap off and feels like it will break if I pull **** it. The two pins look like plastic rivets almost.
Its a 2005 Rinker Fiesta vee 270
I can but it will take me a day or so to get back down to the boat.
ok, apparently the access to the AC unit is under the mattress and not in the wall, so I believe that I am all set. Thanks for your help.
That is the access to your ac unit, the panel with the 2 plastic caps.They simply pop off and there is a phillips head screw under each 1.Remove the screws and the panel comes off and you will have access to your ac unit.
Anything that looks like a button pops off and a SS phillips head screw is under it on the interior
