How do you repair an airlock for a Marine Air System?
I have a 06 342, The fan comes on for air conditioning but no water come out the thru hole and the system won't cycle to heat. thanks Paul
Best Answers
luckydog
Member Posts: 316 ✭✭✭
I had the exact same problem on my 312, if your pump runs, And your strainer is clean. I had to re-prime the line, And now it works as it should. If you keep your boat out of water make sure to shut the seacock to the A/C Before you take it out. -
MarkB
Member Posts: 3,996 ✭✭✭✭✭
You can reprime the line by cracking open the flange to the pump a little. Not a lot! Don't want your boat to sink!Boat Name: King Kong
MIKES342
Member Posts: 182 ✭✭✭
I believe if you can run a hose to your overboard discharge and put water in the discharge it will prime. It is a pain to do it by trying to purge using the strainer to make sure it is full of water. It normally will take several tries.
Dream_Inn Member, Moderator Posts: 7,818 mod
I usually do what Mike stated. If you do a search, we had a good discussion on this recently...I remember MT getting a bit wet in it as well, pretty funny discussion worth reading.Dream 'Inn III -- 2008 400 Express
Lifes Good Member Posts: 465 ✭✭✭
The easiest way is to take a hose and run high pressure water say from your dock and through your water exit from your system. You'll hear the air bubbling up from under your boat. The other is to just run your boat at cruising speed and that will blow the air out too. -
gslpro
Member Posts: 222 ✭✭✭
I use either the water hose to the outlet, or if you can reach it, I use a wet vac while running the unit and it primes it right up. The easiest, and most fun, way is to take the boat for a ride.Gary and Diane290 FV Nauti Bonnie -
Wow, you must be somewhere near me. What a beautiful weekend it is! Ashame the boat is away, but nice weather to help another winterize their boat. Next weekend's weather doesn't look so good, so I'll be glad all is done. So where on the South River are you?
As far as cycling for heat, you may need to program it (did it today on a buddy's 2005 342). P-1 setting needs to be either on 0 for Auto or 2 for Heat. Also check P-13 and P-15, then make sure the final P-17 is set to Nor, not Rst.
luckydog
Mine did the same thing it ran the water up to the filter but wouldn't push it all the way to the AC, I had to prime the entire line From the AC to the pump
Paul, is it actually in heat? does the little light where the sun is light up? If not, then you are not going to have the pump kick on because it is not warm enough to kick the a/c on. To program it, hold the power button on for ~5-7 seconds. It will then flash P-1. Use the fan button to cycle between the different settings, and use the arrows to change those settings. Just for something to try, check the first P-1 setting. If it is not at 0 (which is auto), but at 1, then you will always be in a/c, which again does not kick on when it's this cool out. (although it might tomorrow with temps in mid 70's). P-13 and P-15, along with P-17 (which needs to be nor, not rst) will also affect it. I'm pretty certain this is your issue, unless you are hearing your compressor kick on.
FYI, your pump is located port side in aft cabin under the cushion.
Welcome to the site! I keep my boat at South River Marina, but I'm sure you've seen it at your marina since I know Brian pretty well. He's done a lot of work on my boat the past couple years. I've also recommended him to many other boat owners. If you ever see me out, stop on by. At times, we've anchored out next to the little island there in the Rhode.Dream 'Inn III -- 2008 400 Express
Michael T
Member Posts: 7,235 ✭✭✭✭✭
JC 290 I've been doing the household chores for three months to get the Admiral to refrain from posting that video. She tells me if I keep it up for another three months she'll give me her tablet and I can delete it. I'm not sure if I trust her to have not made a second copy, but what choice do I have? MT
Home port: Hammond Ind.
XXX
