High temp warning
rasbury
Member Posts: 8,990 ✭✭✭✭✭
Working through a cooling issue...I have a bravo III/350 set up, 2005. I have a water temp sensor at the thermostat on my 1/2 fresh water cooled system and what appears to be a water pressure sensor on the power steering cooler. If I have the audible high temp go off, I assume that is on the closed loop side of the system and not the raw water which appears to only have a pressure sensor....is there any gauge or anything for that I'm missing?
Best Answers
TikiHut2
Member Posts: 1,431 ✭✭✭✭✭
My old brass RWP was replaced with new brass RWP(complete w imp).
I admit I lost track of this one so I guess I missed the part where the belt broke on a start. Was the RWP seized up? If not, did u determine that it wasn't the RWP and find why it broke?
>>So there's ENORMOUS flow from the output side of the RWP with the hose temporarily removed when the engine is briefly run on the muffs???
TGM
2004 FV270, 300hp 5.7 350mag MPI Merc 305hrs, 2:20 Bravo3 OD w.22p props, 12v Lenco tabs, Kohler 5kw genset, A/C, etc.etc...Regular weekender, Trailer stored indoors, M/V TikiHut, Sarasota, Fl -
rowboat212
Member Posts: 74 ✭✭
Your belt broke?
You may have a seized or about to seize engine circulation pump.
The dash gauge is your engine temp. There are audible alarms for both. Your engine circulation pump ain't pumping your risers, it's pumping through your block and exchange... That's all the circulation needed on a closed system. Your thermostat controls the volume of flow through block and has notta to do with risers. Your raw water pump is what pumps the risers...
If your dash gauge is reading hot, then it's the closed system. -
MarkB
Member Posts: 4,009 ✭✭✭✭✭
Tiki your Canadian friends will be in your playground in just over 2 weeks.Boat Name: King Kong
TikiHut2
Diagnosing this is extremely frustrating with only fragments of the story and multiple threads on the same topic and 212 is dead on target.
If the RWP siezed it was the problem (and possibly the engine pump too). Obviously the next thing in-line is simply replacing a properly tested thermostat. The engine water pump is the 3rd part of the system followed by blockages in the lines >> manifolds and headers. Have you confirmed any overheat warnings with an IR temp gauge too? Good luck I'm moving on.
Mark, there's always room for another snowbird. You and the family need to get a family boat to keep down here.
Cya soon. MnK
rowboat212
Member Posts: 74 ✭✭
That bearing squeels like a demon because of the fan... That heavy clutch fan is what breaks the seal and wears the bearing... Your floater ain't got one.... It does have a paddle, though, and that paddle can and will wear to nothing over time and never give a hint it's bad except for reduced flow... Google pictures of worn engine water pumps for what I'm talking about... You're likely to have an ah-ha moment.rasbury said:thanks 212, so it sounds like my raw water pump, even with the scoring may be ok after all. I would assume if the engine circulation pump were bad, like a car, it would be leaking water if the bearing were bad or otherwise if seized would be making a heck of a noise which it is not. I will test the new therm. and put in this weekend and see where I'm at!
Thanks, -
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Good comment 212 (aka xxxxxxx) lol The engine circulation pump vanes can and do wear/corrode away leaving you with little to move the coolant. Too much belt tension is another killer of the belt drive accessories too. You can over tension a belt..few people have the tools or bother to do it right and just use a prybar to make it a guitar string. Ultrasonic tensioners are the best. -
luckydog
Member Posts: 316 ✭✭✭
ras, Good-luck hope it does the trick for you, I'll have my wife do an Indian dance for you to make sure it fixes it once and for all
What size hole would yo suggest.....
Once again....... tried that thermostat idea when mine was at your stage Ras. DID YOU TRY THIS?? >>>>>> If water will freely flow from the foot intake with muffs on, to the point it attaches at the raw water pump intake......AND it WON'T flow when cranking the key (with the input reattached) and output hose detached AND your raw wtr pump looks like mine did......then replace the W_____P____. (Fill in the blanks)
Pics taken 18mths ago after somebody here mentioned tiny holes would prevent a problem with no flow. It didn't fix my need to replace the raw water pump. Good luck.
Mike
Let's review:
pic#1 unacceptable wear that I considered barely discernible but it prevented prime even with all the vanes intact but I remained in denial (sound familiar?).
Pic#2 Tried tiny holes in thermostat to no avail.
ENORMOUS stroke of bad luck. I got defective OEM merc impellors from quiet recall.
CONFUSING THE MESS BUT STILL NOT THE PROBLEM!!
The eventual fix..... a COMPLETELY NEW RAW WATER PUMP as a few others on RBOC tried to explain to me too. Puller borrowed from auto parts store. NEW pump in place in 15mins, it was pumping water perfectly. END OF SAGA. Almost 100% sure it will be yours too when you finally surrender to the obvious like I eventually did. Aside from blockage and an easy test of the pump(above) it'll be over soon.
PS. Bribes and trinkets may be left at my front door.
