Cheaper Gas
halifax212
Member Posts: 560 ✭✭✭
Great, just as most of us have laid up for the winter, gas is on sale! It would be great if it holds until next summer. Might help Tiki sell his boat!
Len & Robyn 342 FV Freebird
Ray
2006 390
Previous 2000 340
Look, fellers, Winter blend is a no go in my boat... I hate using it in anything, and I won't run it in anything not computer controlled (retard timing, adjust long term fuel trim reconciled by short term), else you take a risk of predetonation which is pretty ugly in minor form, but just plain fugly in catastrophic form. y'all use it if you want, but my rigs topped off with the last of the summer blend recreational fuel, and will only be cut with winter blend recreational fuel as needed.
Be nice to your fuel system and engine, and it'll be nice to you. these prices aren't Crystal clear... There are angles.
Tietsort.....
I try to buy my gas at Pittsburg Marina. It is run by the city and is the cheapest gas on the delta. Their gas is Valvtec marine gas. Their web site has a phone number you call for current price. It's about a 10 mile trip from my marina to Pittsburg but worth the trip. My marina charges $4.55 a gal so difference is $.66/gal. I usually buy 100 gallons and spend the day fishing in the area.
I am at Lauritzen Yacht Harbor right next to the Antioch bridge.
Where are you at?
Len
Dave
Moon Township, PA - boating in the Ohio River
hey didnt the gas companies say last fall that winter gas is more expensive than summer gas? And then in the spring say that summer gas is more expensive than winter gas?
There is truth that winter weather needs more combustible fuel to initially ignite... Okay.. thirty seconds after starting your engine you're good... To address the need for combustion, they add butane which is a hugely abundent by product of distillation... Okay.. makes sense. Uh... why not... Sure..
Do you want to play a game?
Take a container with a gallon of fuel and sit it inside your heated garage and Mark the level with a marker... Then, take it outside in the cold winter air and allow it to settle to ambient temperature.. Mark that level.. compare the marks... Colder is denser and the same gallon displaces less space. Take it back inside and allow to settle to inside ambient temperature. you'll notice the mark goes back to or close to the first one. for speaking terms, let's say that the difference in levels marked is a pint at the outside temperature.
Pumps measure volume, as defined by space/displacement. If the pump tank in the ground is cooler, the fuel is denser, and you get more than a gallon... If it's warmer, you get at or less than a gallon... You're almost guaranteed to get more volume to displacement when it's colder... Oil companies know this... Therefore, the fluff the fuel with compounds and fillers, mostly butane, to attempt to even out the 'losses' they would incur otherwise...
Now I've told you two reasons for winter blends.... Which do you find more likely to be true, knowing the oil companies?
To further complicate, it's estimated there are no less than a dozen blends across the nation at any given time... Some cities, such as LA, require their very own... Go figure..
I bought gas today for the car at $2.599/gal in Stockton CA. The price of Valvtect marine gas at Pittsburg (CA) marina is at $3.49/gal. I don't know if the marina gas is going to go down enough in the future to offset the 15 cent/gal new tax that will go into effect in Jan. I don't use the boat a lot in winter and have about 1/2 tank now. It will probably last me 2-3 months. Wish I knew what the price will be in 2-3 months. Guess I will just wait and see, .$15/gal won't break me.
Will be going out next week and doing some fishing, will be thinking about you guys with your boats in storage.
Len
