Mystery of leaky portlight in head solved.
I was under the shrink wrap this weekend doing some more prep.  I decided to re-look at the leaky portlight in the head.  Last time I didn't notice the caps for 2 screws in the hinge.  Duh@me.  So I removed "all" the screws this time and the portlight fell right out.  On closer inspection I noticed there was NO seal of any kind.  No gasket, no caulk, nothing between the portlight and the fiberglass.   :#
So I think it's safe to say I found the cause of the leak.  The bigger questions is: How in the world did this portlight get installed without ANY kind of seal?
Think it's time to check on the portlights in the V berth.   :/
    Same reason they didn't tighten the engine mount screws on my port engine. Two out of six were tight and the rest were finger loose... had to remove the engine to get at them... I will take the port window problem any day...
    I can tell you on my 342 the lack of caulk on the portlites eas impressive. lol. I rebedded all mine. Used almost a full 14oz tube per portlite to reseal them properly.
    I thought you used tape?
    Butyl tape.  Buy a roll and you'll never caulk another window.
    I plan to re-seal the static windows with Butyl tape.  For the portlights I'm planing to use 4200.
    I used tape on sealing my bow rails and hatches.  The portlites I caulked.  I did not use 4200 as it might be a one way trip if I ever had to get them out for some reason.
    The trouble with the butyl tape on the portlites is the SS trim ring is really flexible and concaved in shape where it meets the hull.  Then you have to seal the insert to the SS trim ring too (the actual window frame insert).  No way to do it without somesort of caulk.
    The hatches are perfect for butyl tape.
