Mystery of leaky portlight in head solved.
Stodge
Member Posts: 2,738 ✭✭✭✭
I was under the shrink wrap this weekend doing some more prep. I decided to re-look at the leaky portlight in the head. Last time I didn't notice the caps for 2 screws in the hinge. Duh@me. So I removed "all" the screws this time and the portlight fell right out. On closer inspection I noticed there was NO seal of any kind. No gasket, no caulk, nothing between the portlight and the fiberglass.
So I think it's safe to say I found the cause of the leak. The bigger questions is: How in the world did this portlight get installed without ANY kind of seal?
Think it's time to check on the portlights in the V berth.
I thought you used tape?
The trouble with the butyl tape on the portlites is the SS trim ring is really flexible and concaved in shape where it meets the hull. Then you have to seal the insert to the SS trim ring too (the actual window frame insert). No way to do it without somesort of caulk.
The hatches are perfect for butyl tape.
