Outdrive does not stay up
2005 Fiesta Vee 270. Outdrive does not stay up... How do I determine if the problem is with the pump/valve body or the ram ?
The outdrive goes down slowly by itself and can be pushed down with my hand. Tiny leak (not even a whole drop) at the top of the ram cylinder. Pump motor sounds good.
Thanks, Jim
Can you also push the drive up by hand?
A pump rebuild kit costs under $100 and can be installed in a couple hours.
Mercruiser part 18545A1
Thanks. This model has only one ram. I didn't try pushing the drive up. I'll check out that and the valve body.
Would you expect to hear fluid moving in the valve body when the drive is pushed down?
Jim
