Rinker 276 speaker amp location?
bwgoodwinbwgoodwin Member Posts: 11
I recently purchased a 2013 276 RLS Bowrider.  Does anyone know where the Kicker amp is installed at?
I have the manual and see that RCA are plugged into the head unit, but no clue where the amp is.  I am replacing the head unit with a newer model that has more preamp outputs so that i can get better performance from the amp.
276 BR VP 6.0 380HP Duoprop
    I'd like to know too, as I'd like to upgrade the subwoofer and speakers also. Mine is a cuddy though.
    2013 276 Cuddy ~ 350 MAG / B3
    I remember replacing an amp on a 246 that was behind the storage area on the port side of the boat next to the Admiral seat.
  • bwgoodwinbwgoodwin Member Posts: 11
    Found it.  In the starboard storage under the sink (where the firdge is if you have that option) there is a panel in the back of the compartment with four screws, the amp is mounted behind the panel
