Rinker 276 speaker amp location?
bwgoodwinbwgoodwin Member Posts: 11
I recently purchased a 2013 276 RLS Bowrider.  Does anyone know where the Kicker amp is installed at?
I have the manual and see that RCA are plugged into the head unit, but no clue where the amp is.  I am replacing the head unit with a newer model that has more preamp outputs so that i can get better performance from the amp.
276 BR VP 6.0 380HP Duoprop
    JoeStangJoeStang Member Posts: 1,116 ✭✭✭✭
    I'd like to know too, as I'd like to upgrade the subwoofer and speakers also. Mine is a cuddy though.
    2013 276 Cuddy ~ 350 MAG / B3
    I remember replacing an amp on a 246 that was behind the storage area on the port side of the boat next to the Admiral seat.
    Found it.  In the starboard storage under the sink (where the firdge is if you have that option) there is a panel in the back of the compartment with four screws, the amp is mounted behind the panel
