VesselView instead of N2K Gateway?
diggin2day1
Member Posts: 1,331 ✭✭✭✭
I currently have a NEMA2000 Gateway which sends engine information(RPM, oil pressure, water temp, GPH, etc..) to my Garmin 741xs. My problem is that I am running out of "real estate" on my Chartplotter when all that info is displayed. I have a full set of analogue gauges that have been temperamental(especially the tach... Sometimes shows a 600rpm difference!). I am considering fabricating a new gauge panel and installing my Chartplotter and a VesselView 4 into it(and removing analogue gauges). If I were to do this, can I remove the Gateway from the system? Would the VesselView replace the Gateway and output the N2K data to the network? If so, I should still be able to view engine information on my Garmin 741xs right?
You and your boat will be much happier with an all-digital helm! If you want to abandon the analog trim indicators, you'll need compatible trim sensors. Same with fuel levels.
On mine, even though the tachs are flaky, the engine sync gauge works fine. If yours is the same, consider keeping the sync.
And I love the autopilot. I think it makes me more engaged with the boat, which some people might find counter-intuitive.
I'm moving, gradually, to a mostly-digital or all-digital helm. That's why discussions like this one always grab my attention.
Oh man, group hug here! I could use one since my Buckeyes just lost today!
I will say my vesselview has helped me too many times to count when an alarm went off. The last time was for low gear lube (it was not low, just needed a little playing with) and would not have found it.
