Fuel Filter
rasbury
Member Posts: 8,972 ✭✭✭✭✭
I have posted this before and either I was unable to understand the answers but still trying to resolve. I want to replace my inline fuel filter. I went to Marine Max which could not offer any assistance. I have the 350 MPI motor and know enough about filters to know that they are rated to pass a certain amount of fuel. I would think if you put one on there that does not supply enough fuel, you could lean out the motor which would not be good. I've looked at all sorts but just can't seem to identify what I need....any help?
Are you asking for what type of filter you need? Marine has some nice water separators as well.. I would go with one of those vs a straight automotive type inline filter.
It also depends on the sensitivity of your pump type. A old school mechanical pump you could probably get away with a fine mesh type filter. For a performance inline pump like a Aeromotive A1100 type, you need a prefilter and post filter minimum, as they are VERY sensitive to ingestion of junk.
Ras,
Hear is link to Mercruiser filter part number 27. I have used a Sierra brand also.
http://www.mercruiserparts.com/Show_Pictures3.asp?dnbr=884717&ivar=images/COMMON/1354.png&inbr=8093&bnbr=80&bdesc=Fuel+Filter+and+Boost+Pump(BRAVO)
Rob
http://www.amazon.com/Fuel-Filter-Mercury-Mercruiser-35-864572/dp/B001H3FS9W
I'm averaging 50 hours run time per season.....I change my fuel filter (cool fuel module) after I run the first tank of fuel out at the start of each season. Am I changing my filter to often. The average cost is about $90 Canadian for both filters.
Ras,
Yes you do probably have a fuel cooler, just not like the newer version with filters. I am attaching the link to the 350 MAG like mine. Scroll down to Fuel pump and fuel cooler. Open that and you will see what the older version is like. If you need to replace the fuel pump on this version you will see that is no longer available and there is a link to a service bulletin that shows the fuel cooler kit available.
http://www.mercruiserparts.com/selectDocs.asp?doc_nbr=884717
Rob
