re painting out drive
rasbury
Member Posts: 8,990 ✭✭✭✭✭
There are numerous threads on re painting drives, surface prep etc. and what types of paints to use. On mine, I have paint that is starting to bubble and its right in the area where the lower part of the foot joins the upper part, right above the prop. It looks like I would need to remove the bolts that hold that together to get in there are get that corrosion out and painted- will that likely cause the lower part to leak, should I pull it apart (not really wanting to do that) so I can reseal? I think if I pull the bolts, finish and put bolts back on the good way to go but don't want to solve one problem and create a much bigger one!
Best Answers
Handymans342
Member Posts: 10,375 ✭✭✭✭✭
Randy. What kind of paint? I'm using rustoleum self etching primer and RO high performance enamel -
Handymans342
You cant protect every square inch. Self etching primer means that the primer will adhere itself to the bare metal. Hopefully I will get to mine this week
Off subject, What are you pulling it with? I just bought a 99 ford f350 single wheel, 7.3 just for towing, but have not tryed it yet. My daily driver chevy half seem like it was to much load, and I was afaid to go to fast or interstate driving. Your rig looks good.
Did you try it yet handy? I may do a little clean up/prep work but had planned to first, search the site for others comments. If I do not find a better answer get the merc primer and paint. Nice today, wish I had whatever now. Still concerned about getting the corrosion behind those nuts but no one is commenting on that.
http://www.amazon.com/Moeller-Green-Chromate-Primer-Outboard/dp/B000N8LR24
f
