both tachometer not working
Ransnan
Member Posts: 81 ✭✭
I have a 2003 342 with horizon 350 mag MPI, couple months ago the starboard tachometer started reading about 2000 RPM higher than what it should be at cruising speed, and 200 rpm higher at idol, Now the port tachometer is reading about 1400 lower than what it's supposed to do be at cruising speed, any ideas or suggestions on what it could be ?
Ray
2006 390
Previous 2000 340
Here it is.
Paul
So I went with Floscan that has a built in sync gauge, and I replace the Faria sync gauge with a dual hour meter, the floscan tach when in sync both engines are running within 50 RPM. That was check with the Rinda scan tool.
your first question was regarding the lighting pigtail........?
schematic for tachs connections on 5.0 MPI.
- if only one Engine is running , will the sync gage be functioning , and in this case what would be the position of its needle ?
- if the sync gage is not functioning (working) at all , what would be the reason and would it affect the proper functioning of the tachometers ?
- To my understanding , i can assume then that if both the sync gage and the tachometers are functioning properly , then either if in idling stat or full speed stat the gage should always be in the middle !! am I right ? Thank U in advance for your cooperation .
Hisham Kinani
I am much interested in your suggestion re the fuel flow meter , but I need to know what is it and how it works , where should it be mounted , will I be needing two meters or only one and finaly from where can I buy it.
Again thank you very much for your cooperation and apologize for any inconvenience . Hisham kinani from Cairo , Egypt .
http://www.floscan.com/html/blue/recreationalmarine.php
This is the one I have.
http://www.floscan.com/html/blue/seriesdetail.php?sid=14
