how do I get the inner race out
rasbury
Member Posts: 9,016 ✭✭✭✭✭
I have my trailer at the house for my 270 as I have one wheel I lost the outer bearing on. I was able to remove the outer bearing race no problem. The inner race has no lip on the back side of it to knock it out- what's up with this? If you look through the hub, the lip that the outer race rests on you can see. This surface then tappers down to where the inner race is and is absolutely flush to the race with no lip to knock it out? The calipers are std. Kodiak and would guess the hubs are too. Everything I see on line there should be a lip to knock this out!
Best Answers
rasbury
So I got a dremal type grinding tool from a neighbor and ground a couple of grooves so I could get a punch to the back side of the race and was able to knock it out...what a pain! Just don't understand why they made it that way... -
rasbury
That's what I was looking for but nothing there- had it clean as a whistle- so I had to make my own! -
rasbury
3 more to go...at least I should have the one wheel done tomorrow night so I can pull the boat out of the water...
