hole in my black water tank
rasbury
Member Posts: 8,737 ✭✭✭✭✭
In a previous thread I have all sorts of "fluid" issues down in my engine compartment, one pretty stinky. It seem to be a pretty intermittent problem with the tank and I think an issue since we bought it. I finally broke down today and pulled the tank out. On the side up against the hull there is a perfect small hole, about 1/8 to 3/16 in diameter. I don't think anything would have poked a hole like that, its pretty thick anyway. I don't see anything around it that would have done it. I guess I will be able to put some sort of plug in it and fix it. Also, I assume to would plug it from the inside and then eventually it would move and leak...very odd!
Depending on the size, you could always fit a screw into it with epoxy. But, I think the permatex is worth a shot.
