Checking for water in gas tank.
Another question:
I have a 2008 260ec and during a trip last year left the gas cap off. Dumb! Anyway would like to check for water in the fuel using water detecting paste. There does not appear to be any easy access to the fuel tank where I can lower a wooden rod in to check. It appears the best access is through the sending unit. I assume if that is the best access I should replace the gasket if I remove it.
Thoughts anyone?
Many Thanks
Thanks to both of you! I will try your suggestion first!! many Thanks
Ben
