342 anchor locker leak
If anyone has a mystery leak of water to the mid-berth bilge, check your anchor locker. There is a square plate screwed in to cover the access hole to the anchor locker drain thru hull. The plate was poorly sealed on mine. Removed, cleaned and resealed. You have to work thru the access plate behind the mirror but very doable.
