Friendly Reminder
aero3113aero3113 Member Posts: 10,085 ✭✭✭✭✭
I was working on the boat today and checked all of my hose clamps, most of them were 1/2 to 1 full turn loose. I also looked at the bottom of the oil pan, a couple of rust spots/bubbles starting. I cleaned them the best I could and painted with Rustoleum. Some of you may remember one of my posts a few years ago when I had to change my oil pan because of rust, it was so bad that it was actually leaking from it. Preventative maintenance!!
    Another easy thing to look at is your fuel cap o-ring. I looked at mine today and it needed to be replaced! The part number is on the bag if anyone wants to order some.
    Thanks will check mine.
    A surprising amount of water can get past a bad fuel cap O ring - never a good thing.
    I recently had 2 gallons of water filtered out of my starboard tank due to a missing O ring.  I'll be checking them often now.
    Ordering today! Thanks.
    I replaced my gas caps because of the same reason
    Most gas boats just run fuel filters and not water separators.
    so replace o rings or in my case entirand flip up cap
  • MsquaredMsquared Member Posts: 30 ✭✭
    Will check this weekend. Great call
    Also out on my to do list for tomorrow. May as well check water and waste too, not as much of a problem but worth checking anyway.
    edited September 2023
    I followed @aero3113 on this and replace them every 3 years no matter the condition. Water in the tank is a pain as you know. Check them first before replacing the filler
    Thanks @Pat310 !!
    I was looking for this for @echandler1971 !
  • captkevincaptkevin Member Posts: 617 ✭✭✭
    Great tip
  • echandler1971echandler1971 Member Posts: 249 ✭✭✭
    Thanks @Pat310 !!
    Yes, mine literally have no gaskets at all (never knew they had them). The replacements come with a redesigned offset ring that lifts the port face 1/4” off the surface of the transom and has a shape to push water away. Also, new ports will have actual functional gaskets so I won’t need to have 30 gallons of water pumped from my tanks again. Until then, i have fashionable tape covering the ports.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    Never thought about this and never looked. Will be on my next trip to the boat. Good idea!
    I remember my dealer making a big deal about checking the O-rings each spring. I lube them up with dielectric grease. Water, waste & fuel caps.
    I was shocked when the boat was in our driveway on the trailer & a rainstorm hit...a phenomenal amount of water was routed down the arch to the boat side - right across the fuel cap. Gallons & gallons.
