Wow, you're right. I didn't see it in person because it's hard to get to. I stuck my phone above it and took a pic.
The problem started when I was using a automotive charger on the docks at put-in-bay for the weekend. (I know, please no bashing). It was a smart charger connected to the house battery just to keep it charged for the weekend.
I also blew my drive down trim solenoid that weekend, so I likely had some kind of power surge. Maybe the burn mark on the isolator shows that?
@JoeStang that center wire is directly from the alternator (Volt meter to verify) Varify the start and house #1. #2. 12.7 engine off 14.+ or - after engine fires up Check this at back of alt. then center pin Now check the other pins on the isolator. (This is where my charger connected) The pins should show 14.+ or - if so the battery should so 14. My guess is the +wire form the isolator is not connected to the house battery.
I would start at the isolator. That seems like the common point. If you were charging just the house battery, the isolator probably didn't like the current running backwards thru it. Think of it as a one way valve.
Looking at the photo again: my guess is a loose connection. That would cause heat, which would cause carbon buildup, which would increase resistance and start an endless cycle. Until it wasn't passing any current. This would discolor the caps (as seen) and lead to one side of the isolator not charging.
So I finally got around to swapping the isolator with a new unit. It was the culprit.
What looked like burn marks on the rubber boots was not from heat, it appeared to be grease/dirt from whoever installed it from the factory.
Voltage to all batteries is 13.8-14.0 regardless of switch position now, which is how it should be. Now I wont have to constantly move the switch back & forth depending if I'm running or anchored.
12.7 engine off
since it’s really down to the isolator or the switch now
If the isolator is still good.
