New owner of an 04 342 FV
Hi everyone,
Closed on a Rinker 342 last week, unfortunately its 3 hours away and with Chicago winters I wont get my hands on her again till spring.
The first thing I really want to do is change the speakers, I know there is 6 6.5in in the cockpit and 2 in the cabin. It looks to have the stock sony setup, so my question is what size is the sub? Also if its a 12in has anyone installed the JL Mseries in the same spot? I know that thing is beast and needs 20in of depth.
Has anyone changed the head unit and found something compatible with the factory remotes or can you recommend what you used to replace the factory remotes and was able to cover the existing holes.
Thanks in advanced!
Thanks in advanced!
Congrats and welcome!
Right now I'm under the assumption from a friend with the same year and model that it has a Sony 12in sub from factory (Which to be honest I'm hoping its 10in) If that is the case I was looking at the JL M12 which I was told by a JL dealer that it was almost double the size of the M10 and needed a ton of space. Looking at the specs though its about 9in for depth so not horrible.
The Kenwood system mine came with has an 800W amplifier. It is located under the starboard srorage bin in the v berth.
We plan to do a trip to Georgian Bay but not until 2021. Too many other vacation plans in the way until then.
