Stereo wired to ignition key - hour meters run when stereo is on
LaRea
Member, Moderator Posts: 7,567 mod
To run the stereo in my 2007 370, I have to turn the port ignition key to the first click (accessory position). Unfortunately, I just realized that the engine hour meter is running in this position. This a problem because it adds bogus hours to the engine hour meter every time I listen to the stereo. Anybody else have this problem?
Something must be mis-wired. The hour meter should only be able to work while the engine is actually running. How can I fix it?
I took off the dash panel to look for any obvious labels in the wiring harness, but saw nothing of immediate value.
--Chris
Ray
2006 390
Previous 2000 340
Chicken dinner!? Well, better than nuttin'!
Tiki, I can see the actual hours with my vessel view. My actual is definitely a bit lower than the tach (like 30 on one and 20 on the other). & thanks to the first weekend with the boat (when I had it still on the hard cleaning it), I put about 9 hours extra on port side tach.
