Electrical outlets only working when connected to shore power..?
Nick_03FV310
Member Posts: 17 ✭
Have a 2003 FV310 and noticed Saturday while out on the water that none of our electrical outlets work when we are anchored down in the water. I looked at all breakers in the cabin and none of them state "outlets" and I've also tried flipping every single one to see if they gave power and none did. Then when we got home for the day and connected to shorepower, they all worked again. Is there another switch or breaker I should be looking for somewhere? I checked the battery switch panel as well and couldn't find anything.
Thanks!
Thanks!
Nick: there are a few options depending on what you're trying to use it for. Easiest thing is to maximize the 12V stuff: charging cell phone? Get a car charger. Charging laptop? Get a car charger for the laptop (DC-DC buck converter). Watching TV? Get a 12V TV.
Mid-draw devices, like a gaming system or toothbrush charger (my life goal is to stay on the boat long enough my brush dies): install an inverter. A small 500W inverter will run most devices in your home that aren't hardwired in, save a hair drier or curling iron.
Want to run the AC on battery? Win the lottery. The larger draw the device, the larger battery bank and inverter you'll need.
Want to add a generator to charge battery and run AC? Get a 2000 watt unit and set it on the swim platform. Get a handful of 10-year battery powered CO detectors, keep them turned on and near the heads of sleeping persons. This could save your life.
Have fun!
In lieu of this electrical talk -- What are your thoughts on running the radio with the subwoofer on, on battery power only? From my automotive sub days, I knew that a car battery couldn't handle a subwoofer for too long without draining it. Does this go the same for the marine side of things? Our sub is connected to an accessory switch and I've pretty much always turned it off once the engines turn off. Standard practice for others?
Many of us run a stereo all day on battery with no issues.
A subwoofer and amp would likely be fine for an 8 hour day. If your concerned get a 100W solar panel and a controller - it'll keep you topped off.
