Oil pressure question
A few years back I had one of my Mercruiser 5.0's replaced with a Jasper based upon the Mechanics recommendation about a better warranty. When I took the boat back he mentioned that Jaspers tend to run higher oil pressure and that was why the gauge was reading close to 80psi when I took the first test drive. Fast forward a few years the pressure reads at or above 80 when I'm at about 3/4 throttle and I don't want to push it further. Is the mechanic full of it or do I need to get a new sending unit/gauge so it doesn't bother me?
Thanks,
Brian
Thanks,
Brian
It does, however, keep the valve train oiled better, and the cam, except for the back of it on that dizzy drive.
A hole for draining tapped above that gear and a larger sump (more volume of oil) solves this riddle.
