Thru hull fitting replacement 342FV
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
I pulled my A/C water outlet thru hull to replace/rebed as it was looking sorry. It fits a 5/8" hose (all the barbs were filed off..interesting), but I can't find a replacement with a large nut like the original. Anyone have any links to one. Picture attached shows the old one Vs a new one. You can see the large difference on the nut side, the threads are not the same on the two so I cannot reuse the old nut.
Best Answer
OptionsDream_Inn Member, Moderator Posts: 7,563 modI would think you could find an appropriate washer for it. That is the route I'd go. Although I think SS would be better yet, I'm not a fan of those marelon ones.
