mercruiser analog to nmea2000 engine data?
army_greywolf
Member Posts: 12 ✭
Anyone running a analog mercruiser to nmea 2000 engine data converter? I'm looking for someone who has done this, converting the analog gauge set to nmea digital gauges. I could eliminate a huge amount of wiring and really clean things up, and also plug it into the existing network.
The steps are:
1) Install a gateway that converts engine data to N2K.
2) Connect your fuel tank level senders and outdrive trim level senders to the engine computers.
3) Install a VesselView, SmartCraft gauges, modern MFD, or some other way to display engine data.
4) Network everything together.
What do you have in mind?
https://rinkerboats.vanillacommunities.com/discussion/7295/conversion-to-all-digital-helm-on-a-2007-370
http://www.digitalmarinegauges.com
Also I thought the pcm555 was smart craft.
That the computer on the riser.
