Kohler 5e oil
what are you guys using for oil in the genny? I’ve been using sae 30wt the last 3 seasons per the book but wondered if there is something different or better that I should be using? Thx
    Listening, I have troubles getting the oil out. This year plan to suck it out with my pump. Sae 30 wt.
    Dream_InnDream_Inn Member, Moderator Posts: 7,566 mod
    I use SAE30 as well.  I use an electric pump to draw it out.  Seems to work fine (been doing it that way for 12 years).
    Thanks. I'm thinking I'll just stick with the Valvoline 30wt I've always used. I've just been sucking it out through the yellow cap too, seems to work ok. I always refill from the black cap at the top of the unit. Thx
    I assume when you say thru the yellow cap, you mean the little turn nozzle on the side?  That NPT fitting is where I connect  hose and draw it out from.
    I mean the yellow dip stick. I suck the oil out from the generator dipstick opening and refill from the black oil cap up top.
    You did notice right next to the yellow dip stick is a twist knob and a npt (for a hose connection) to drain the oil?
    Thanks! Yep I am aware, I suck out both mains oil through the dipsticks so I then just shove it in to the generator and suck that out at the same time. Maybe I’ll try the npt this year. Thanks!
    edited September 2018
    Yous guys are learning me. I have use the turn knob, mine has a drain line connected to it most I have got out is about 8oz.
    When I suck out the dipstick on the 5E I dont get the full 1.44 qt out but I do get more than a qt. out.  I really fish around with the tube to suck out all I can (tube is fairly firm).
    Multi weight oil is not recommended.
    I run 30W synthetic with a Wix 51394XP filter
    Got it
    LaReaLaRea Member, Moderator Posts: 7,573 mod
    From the Kohler 5E operator manual.  The note at the bottom says "use of multigrade oil causes greater oil consumption."
    Thanks LR! I’ve got that out of the book, just wondering what the consensus was. Some
    of you have found better filters and what not. Thanks again!
    SpyderwebSpyderweb Member Posts: 880 ✭✭✭
    I'll be changing the oil on my 330 this Fall for the 1st time.  With the oil warmed up, and the top black cap removed (for venting), shouldn't opening the nozzle on the 3/8" fitting allow most of the oil to readily drain by gravity?  I know I change the oil on my snow blower through a 3/8 fitting this way and it flows very readily.
    Spyder, yes it should be able to drain by gravity.  I just connect a pump to it because I already have it in the engine room after doing the engines and it makes it quicker.
    Snyder I have tried this maybe not hot enough but did not get good flow.
    YYZRCYYZRC Member Posts: 4,931 ✭✭✭✭✭
    Seems like Kohler is now recommending 5W30?!
    Maybe on newer gennys. The older ones will consume oil if you use multi-weight. These are all lawnmower engines at heart. lol
    I ran 30W NEO Synthetic oil in my 5e. I ran that genny a lot and the oil looked like new at every change.  Used the WIX XP filter too.
    30W seems hard to find but I'll seek it out.
    aero3113aero3113 Member Posts: 8,841 ✭✭✭✭✭
    I bought 6 quarts from a reputable dealer on eBay last year.
    Yeah but you live in the land of everything great at low prices. Plus a few randos.
    30wt is hard to find. Menards was carrying it, the last season I had my 342 I was ordering it on Amazon. But agree with BD I never burned a drop in the 5e and it didn’t change much in color all season. To the lawnmower point the Briggs n Stratton oil that most hrdware stores stock is 30wt so that’s an option.
    I can buy this locally but the statement about OHV engines is concerning. Pretty sure the Kohler is OHV…?
    goalie59goalie59 Member Posts: 326 ✭✭✭
    15w40 Shell Rotella. Liberty do you not have a diesel genny ?
    Sae 30 is at my local auto store napa that’s what i have always used
    2002 Rinker FV 342
    Hi Goalie, my above comments are regarding the gas 5e that I had in my previous boat, 342 FV. Yes, my current boat is a diesel Koehler genny like yours and I use the same 15w40 in that genny that I use in my mains.
    GrahamuGrahamu Member Posts: 870 ✭✭✭
    I use Castrol HD 30 Heavy Duty SAE 30 motor oil. It's available at Napa.
    Thanks @Grahamu !
    rasburyrasbury Member Posts: 8,264 ✭✭✭✭✭
    I just order it all from Kohler as I like to pay 2x the price for everything....
