re sealing thru hull
So, I have a thru hull with a leak...like the one pictured on the left. I think I may have caused the problem....the hose is my raw water, hose comes up, snakes around by the stringer at the fuel tank and then over to a strainer.....when I step down into the bilge, there is nothing really to step on. Since that hose rested on the stringer, I have been stepping on it.
So, I assume there is a block of wood in the hull to support this. The bolts that come through, are they some sort of T bolt or just a bolt with a washer coming through the other side of the block? How do I re seal this?? I guess I really need to see where the water is coming from at the ramp to determine what to fix on this...geesh.
Best Answers
randy56 Member Posts: 4,085 ✭✭✭✭✭
You can take it off the boat clean, reseal, reinstall. Keep your big foot off.Boat Name : -
skennelly Member Posts: 2,196 ✭✭✭✭
I replaced the type on the right without the flange. Came out easy for me..thr existing sealant just fell apart. I had a strainer too and the 14 year old screws weren't a problem2002 - 270FV Mag 350 B3 -
rasbury Member Posts: 8,509 ✭✭✭✭✭
ok, so, when I went to work on this, my thru hull is like the one on the right. The thru hull for the geny is like the one on the left, however, there are no bolts through the 3 points like above. The sealant used was soft and will replace with the same....so is there any sealant used when the valve goes on the "stem" of the thur hull or is is it just where the contact surfaces for the hull and the screws from the strainer?? -
zaverin1 Member Posts: 1,672 ✭✭✭
My buddy had a 2500 diesel Chevy 2012
4x4 crew cab ltz
it got owned many times by my old dodge hemi
yes he had torque but not blow off the line
