Water Pressure
Anyone have an opinion as to what is causing low water pressure as shown on the below pics. The first one shows water pressure at idle and the second shows water pressure at cruise. I have already switched the water pressure senders, port engine still shows lower pressure. I also replaced the impellor on the port engine, no change. This problem just started a couple weeks ago. Thanks.
The
The
Also maybe water inlet hose is pinched or collapsed?
IMO - I think your port engine would be much hotter if it were only receiving < 2 psi at almost 4K rpm.
On my port 2014 Merc 502 we had to replace the psi water sensor THREE times to get a correct reading.
At first the Merc doubted it and replaced - under warranty - several other expensive parts and a lot of labor, but in the end it was the friggin' sensor. Lucky for me it didn't cost me a cent!
Good luck with the trouble shooting!
reneechris14, I'll check with the mechanic who replaced the impellor on whether or not he noticed any scoring in the pump. Thanks.
Exactly what I was thinking as well. If there is scaring, it may only be getting partial water pickup (not fully priming). I've had to replace both of my water pumps over the last few years due to this. Look in to the stainless Hardin pumps.
My point is, if low pressure was caused by a block in the suction line of the pump, you wouldn't get flow, and the engine would overheat. If you are maintaining temperature, then you have good flow. If that pressure is real (the sensor isn't messed up), then flow can only occur at high pressure with little to no resistance, which means the thermostat could be stuck open. If it's stuck open, then yes I'd be looking for 120 to 140F temperature ... which you don't have, so it's unusual. Probably another faulty sensor. Can you swap the one from the other engine?
PSI is not about the pump ... it's about the resistance to flow which is everything downstream of the pump. We call that the system pressure. As flow goes up, the system pressure goes up, and the pump and system come to balance (pump delivers flow at the system pressure).
Low pressure would throw a constant horn and put the engine in limp mode. If a water pressure sensor is shorted or open, you'd get two beeps every minute.
Check to make sure VesselView is displaying pressure in PSI and not some other units.
River is clearing up so a good run this weekend I hope to get a better look.
