Water from Shower into Salon
Chennupe1Chennupe1 Member Posts: 5 ✭✭
Hello everyone, I am "hopefully" a soon to be 2004 342 FV owner, however during the sea trial, there were some issues found, some minor, but one specifically an "indoor" plumbing issue. The water from the shower did not drain into the shower pump, but seems to be seeping from under the shower floor into the salon, behind/adjacent to the steps.  Not sure if this is a hose failure and if so, how do I access the hose? Could clog drain cause water seepage into the salon? Any schematics of the shower discharge system available.  Thanks for any help offered.
    The shower sump is located in the mid-berth, on the port side under the cushions.  If the lid is loose, or the box is damaged it can leak.  I had a similar problem with mine and had to replace the sump.  Not major.
  • Chennupe1Chennupe1 Member Posts: 5 ✭✭
    Thank you. We'll check
    Agree with Stodge, likely the pump is not working so the water had nowhere to go
  • billy737billy737 Member Posts: 32 ✭✭
    Had the same problem
    2004 Rinker Fiesta Vee Conroe TX
  • randy9000randy9000 Member Posts: 15
    Stodge,
    where did you get your replacement pump? Do you have a part number?
    Thanks,
    9000
    2005 Rinker 342 - Maryland
    Just by one from west or online
    they are pretty much generic
    Thanks zaverin1!
    Atwood sahara S500 is in my showerbox 05 342
    The sump I got had the same pump as the original, which has decided that it's too much effort to turn on.  I just got a replacement atwood pump for it.
    @zaverin1 is right, they are fairly generic.
  • GMSLITHOGMSLITHO Member Posts: 1,618 ✭✭✭✭
    You might want to tape up the shower drain and fill some water in the basin to make sure the enclosure isn't leaking
    I put in a brand new box and pump a few seasons ago when I bought the boat, same pump that Renee mentioned. For whatever reason for the first shower of the year I have to pull the pump out of the box and re shove it in a couple of times to get things flowing. Now I just run water in the shower to get things going, after that it works awesome for the entire summer, we take several showers every weekend in there, just that first prime of the year needs some attention....
    I have the same problem.  I got a check valve to put in the discharge line but haven't gotten to it.
    I had a leak as well but it was the plumbing, not the drain.  It was running underneath the shower and wicking into the carpet in the mid-berth storage.
  • cls10105cls10105 Member Posts: 389 ✭✭
    I need a new box my lid is missing since I bought the boat. Anyone know what box to get for a 2002 342 fv
    cruising on 6. tw0s
  • aero3113aero3113 Member Posts: 9,767 ✭✭✭✭✭
    edited April 2021
    I was able to just buy the lid for mine. If you know what model sump you have I’m sure you can do the same. Much cheaper than replacing the entire sump assembly.
    @aero3113, I will try and find that today. That would be great to save some money. Do you remember where you got the lid from?
    cruising on 6. tw0s
    @aero3113! Thank you buddy. I really appreciate that.
    cruising on 6. tw0s
    @cls10105 , do you have a pic of your sump?
    @aero3113 , no but I am going to the boat as soon as the little one is picked up. I bought a screen for the hatch I am hoping works and I will take a picture then.
    cruising on 6. tw0s
  • Aqua_AuraAqua_Aura Member Posts: 2,702 ✭✭✭✭✭
    Fisheries supply is apparently a really good boat supplier. I need to make a trip up to Seattle and check them out.
    This thing is not letting me post pictures
    cruising on 6. tw0s
    @aero3113, this is the nasty pic. Can you tell anything by it?
    cruising on 6. tw0s
    @cls10105 , I was hoping for it to be the same as the one I have, but it’s different. Maybe look for a model number printed in the box.
    @aero3113, I will try and find one. Probably next weekend though. Thank you for your time and help it’s really appreciated!
    cruising on 6. tw0s
    It looks like that cover screws on, that might help with finding the correct one.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,920 mod
    I definitely have seen those on lots of the older model Rinkers, but most new ones have the clip lids now.  I can't say I've seen the lids for them for sale.
    do you think this one would work and is a good one?
    cruising on 6. tw0s
  • SpyderwebSpyderweb Member Posts: 958 ✭✭✭
    I had the screw on top type in my Bayliner.  Actually like that better.  Had to replace snap on lid on Rinker last year too because the fins snapped off.  The new on is so tight, I expect them to snap soon too.
    @cls10105 I would think that one would work fine.  Rule makes good products.  Just make sure it will fit in the area and you have a way to mount it (or that mounting it is similar to what you have).  As for clip on or screw on lids, I've never had issues with the clip on ones.  I access mine maybe twice or three times a year to clean it out and been fine so far with the original one (from 2008) still installed.
    @Dream_Inn, ok thank you sir. It looks like it would fit. Why I didn’t measure is beyond me. I took pictures. Lol. We are the process of switching marinas and taking down lights and get my box and stuff. Anyways it was too much for my little brain. I am going this week to make the move. So I will measure it then. I really appreciate all of you! Best site ever!!
    cruising on 6. tw0s
